Logout Redirection not working on new saml authentication service
Hello ,
We created a new SAML authentication service with Authentication service alias "sso3". the login url generated is : https://pegaenv/prweb/PRAuth/sso3
After logging in, in the URL we see that the sso3 is being removed having "https://pegaenv/prweb/PRAuth/app/Default". Is this the normal behavior removing the Authentication service alias "sso3" from the URL? because when logging out, it is being redirected to https://pegaenv/prweb/PRAuth/ instead of https://pegaenv/prweb/PRAuth/sso3 which is failing and not logging in directly to sso3.
To Note that we have saml services created in old pega version where the sso1 is not being removed from the URL, and the logout is redirected to the correct authentication service.
how to fix the logout redirection problem? should we have the sso3 in the URL after logging in?
Thank you, Dany
