Foray Software Pvt Ltd
Last activity: 2 Apr 2018 6:12 EDT
Load Datapage to Text property in UI
I want to load Datapage to section which contains Text properties?
Pls help
Krishna
Hi Krishna,
If your requirement is to display the property values which are available in the DataPage into the section, then you can add the TextInput control on to the section and provide the source property value as D_DataPage.PropertyName, this way you can include all your data page properties into your section as per the type of data available in your datapage.
If this is not your requirement, kindly let us know what exactly you are trying to achieve.
Regards
Mahesh
J.P. Morgan Services India PVT Ltd
Do you have any refresh section configuration on the action set of the repeating grid.?
Infosys
I am new to the PEGA...Please help on how to check this?-- refresh section configuration on the action set
on the drop down, actions tab you can configure that
Infosys
I just verified it. I could not see action sets. Please tell me one thing I have
--> activity which I is created in the Code-Pega-List with only one step that is Obj-Browse. Please same in the first attachment.
--> Datapage which is created to call the above activity. Please see the same in Second attachment.This datapage is giving the 3 records from the external database table
Now please tell me how to bring all these three records details to UI(Repeat Grid section)
sajal n
I am not able to get your requirement .Could you please elaborate it.
YOu can source the Data page to a Repeat Grid /Repeadting Dynamic layout or any repeating structure to show it completly in UI.
Infosys
I have mention the source as DATAPAGE.even though UI is showing the empty records
Infosys
I have created a datapage which is taking the three records/rows from the external database. Now I want to display those three records on repeat grid(UI).
For this, I have created the Repeat Grid Section and mention the DATAPAGE. When I run the casetype I am getting three empty rows(three null rows). Please refer the attached screen shots
Updated: 2 Apr 2018 6:12 EDT
HI,
I think this has been replied in the below mentioned thread:
https://collaborate.pega.com/question/empty-rows-while-loading-datapage-repeat-grid-ui
Piyush Kumar
