Limiting the no.of files to drop in DragAndDrop control
I am trying to customize OOTB draganddrop control to limit the no.of files to be dropped in one go. I am able to succeed in case of Chrome Browser.
There is a separate code snippet for IE browser drag and drop feature.
Before starting the upload process i need to check the no. of files to be dropped.
I tried below in case of Chrome .
function pzHandleDrop(e){
e.stopPropagation();
e.preventDefault();
e.preventDefault();
var files = e.dataTransfer.files;
var count = files.length;
pzNumberOfFilesDropped = count;
pzNumberOfFilesUploaded = 0;
var busyIndicatorSet = false
if (count != 0) {
if(count < 21){
var reader = [];
for(var i = 0 ; i < count ; i++){
if(!busyIndicatorSet){
pega.u.d.setBusyIndicator(document.getElementById("pzDragDrop"),true);
busyIndicatorSet = true;
if(parseInt(files[i].size) <= parseInt("<%= maxFileUploadSizeBytes %>")){
reader[i] = new FileReader();
reader[i].fileName = files[i].name;
reader[i].onload = pzUploadFile;
try{
reader[i].readAsDataURL(files[i]);
catch(Error){/*Firefox throws exception on reading folder*/
alert("Only file(s) upload supported");
refreshFileListSection();
/*Folder drop case*/
reader[i].onerror = function(){
}else {
alert("File " + files[i].name + " exceeds upload size limit of <%= maxFileUploadSizeMB %> MB");
}else{
alert("It allows only 20 files");
I am customizing below rule.
RULE-HTML-SECTION DATA-WORKATTACH-FILE PZMULTIDRAGDROPCONTROL #20170109T024327.463 GMT
Need to understand below code snippet.
function pzInitActivexDD() {
try
var oDesktopInt = document.getElementById("prDesktopInt");
if (oDesktopInt != null) {
var sServerUrl = window.location.href.substr(0, window.location.href.indexOf("?pyActivity"));
oDesktopInt.initDragDropControl(sServerUrl, window, "<%= maxFileUploadSizeBytes %>", "drag_drop_target", "drag_drop_over");
eval('function oDesktopInt::UploadComplete(p1, p2, p3, p4) { dragDropEventCallback(p1, p2, p3, p4);}');
// now display correct label
initActivexDDsetLabel(1);
catch ( e ){
Any suggestions to proceed further.
Thanks in advance.
