Lead System Architect Exercise System
Pega seems to not be starting on VM Exercise system. I keep getting a Tomcat 404 error from localhost:9080/prweb
One possibility is that your laptop does not have sufficient RAM to run Pega 8.3.
When Tomcat starts up there is no database to connect to.
First look at /opt/tomcat/logs/catalina.out
Additional clues may be found in /opt/tomcat/work/*/*/prweb/PegaRULES.log
You may need to result to using a Personal Edition which uses less RAM.
Yes, that was it. I was able to get it to work on systems with 16GB of Ram
