Knowledge Management Framework :Need to search the specific document which are posted in the article
Post an article and attach the document having different name in the knowledge management framework . Now search the document using search functionality . The actual outcome of the search result is zero where the document is present.
The actual search functionality which is given in the knowledge management framework is to search the articles and posts only. But the requirement here is also to search the specific documents too
Steps to Reproduce
1)Login to Knowlege management
2)Post an article and attach the document having different name in the knowledge management framewrok
3)Now search the document using search functionality
Error Message
No results found
