Join with pyGUID not working
Hi! I'm using Pega 8.7.5
I have the class REPO-Reporting-Work-Reporting, where I'm creating a report definition called CasesAndCondominium. Plus, I'm trying to do a class Join between this class and REPO-Reporting-Data-Condominium class. The REPO-Reporting-Data-Condominium class has pyGUID as primary key.
I'm doing the join this way:
Where .CondominioSelecionado is a case property that stores the pyGUID value
of the Condominium class when the user selects a Condominium in a dropdown.
My report has 5 columns: pyID, pyStatusWork, CONDO.Name, CONDO.NumberOfBuildings and CONDO.Description.
I don't know why, but when I run the report, no results are shown. Is there some problem joining with pyGUID of another class?
For testing purposes, I created another column in the Data-Condominium class, storing the same values of pyGUID, you can see below:
And after doing CondominioSelecionado = CONDO.CondID join, it worked...
Can anyone explain me the reason of this behavior? Why joining with pyGUID is not working?
Thanks in advance!
