Anthem
Last activity: 21 Jun 2022 10:46 EDT
Job Schedulers running in loop
Hi Everyone,
On intermittent basis, only in performance environment, Two job schedulers are running in loop and even If we tried to disable and enable them they are still running on the same requestor.
As a temporary fix, we tried to delete and recreate the Job schedulers which helped out but we are looking for permanent answer as the outbound files are getting impacted. No looping in code and nothings in the logs.
Please suggest if you are aware of any similar issues with PRPC863 version ? Also, suggest any debug loggers which would help in this case. Thank you.
