JMSMDB listener question, is it possible to deploy them without downtime of the platform?
We are having a platform with 4 appservers of which 2 are using JMSMDB listeners.
Our platform runs on Websphere and according to this link on the PDN we have to stop and start our appservers each time we are deploying an new JMSMDB listener
https://docs.pega.com/deploying-jms-message-driven-bean-mdb-represents-jms-mdb-listener-pega-7
When we do perform a stop and start, it triggers an automatic restart of the other appserver. Off course, this is not what we want to happen.
We've raised a request at the IBM support site and got this link back.
https://www.ibm.com/docs/en/was-nd/8.5.5?topic=files-hot-deployment-dynamic-reloading
On this site, the text underneath is clearly stating
It talks about the two steps to take for hot deployment.----------------------------------Required: If you are running WebSphere Application Server on a group ofmachines using WebSphere Application Server, Network Deployment and youare changing an application on a particular node, disable automaticsynchronization.Click System Administration > Node agents > node_agent_name > Filesynchronization service in the console navigation tree.On the File synchronization service page, clear the check box forAutomatic synchronization and click OK.When you run WebSphere Application Server on a group of machines usingWebSphere Application Server, Network Deployment and you change a fileon the disk in the expanded application directory for a particularnode, you can lose those changes the next time node synchronizationoccurs. In the WebSphere Application Server, Network Deploymentenvironment, the configuration stored by the deployment manager is themaster copy and any changes detected between that master copy and thecopy on a particular machine trigger the master copy to be downloadedto the node.--------------------------------------Also it clearly states that hot deployment is NOT meant for productionsystems as it could cause unpredictable results.-----------------------------------Important: Do not use hot deployment to update components in aproduction deployment manager managed cell. Hot deployment iswell-suited for development and testing, but poses unacceptable risksto production environments. Full or partial resynchronization mighterase hot deployed components. Also, running the restoreconfig commandmight overwrite changes made to expanded application files. Further,hot deployed components are not migrated between versions of WebSphere®Application Server. To add new components or modules to an enterpriseapplication, reassemble the application EAR file so it has the newcomponents or modules and then redeploy the EAR file.Given the above, you have two properties be set to false in the server.xml file for the nodeagent:
As for as I understand so far, this all is recommended by both PEGA en IBM, thus, STOP appserver, add JMSMDB listener, START appserver.
We allthough want a 24/7 running platform.
Is it possible to achieve that goal or do we need to stop using JMSMDB listeners then and what would be the alternative?
Kind regards,
Arjan Maus
