Cisco Systems
jdt.compiler.useSingleThread= true System Impact
Hi all,
Setting jdt.compiler.useSingleThread=true . How is this going to affect the Performance of Pega application? What is the reason to use SingleThread?
As far as I understood , jdt.compiler.useSingleThread= true the System does the compilation in a single thread.
There are rules in Pega which has java code been compiled every time the rule is being used.
So if I use this setting it will bring down the performance.
