Java class and method is use to capture logs in PegaRules.log
To capture pegarules as business transactions for monitoring in AppDynamics, we need to create a data collector and specify the relevant class name and method. One approach we are considering is capturing the pegarules.log file as a data collector, which would require identifying the Java class and method used to capture logs in that file. What are the java class and method is use to capture logs in PegaRules.log
