Is it possible to generate Data-Admin-Security-OAuth2-AccessToken instances manually?
Greetings. Is it possible to generate the Data-Admin-Security-OAuth2-AccessToken instances manually using token endpoints without having to use Authentication Profile? the token URL that i use is not accepting client secret but in Pega it is a must for authentication if we need to generate tokens via Authentication Profile. Testing the endpoint via Postma works fine, i want to follow similar approach but i am stuck as to how to manually save a instance. Can someone please provide my options?
Bharat
