Is it possible to change the order of the pxFlow pages in 7.3 version
In my business scenario, multiple assignments are open and assigned to Case owner. If the user has opened 4 assignments per one case the pxFlow page order is like below.
pxFlow(OutcomeFlow_1) - This is the third assignment
pxFlow(OutcomeFlow_2) - This is the Fourth assignment
PxFlow(pzInternalCaseFlow) - Internal
pxFlow(Analysis) - This is the First assignment related to "Analysis" Case Type. From here user clicks on the button. Which has activity to initiate a "Outcome" flow on the data class.
pxFlow(OutcomeFlow) - This is the Second assignment
After completion on any one outcome assignment my user wants to see "Analysis" case . But system is taking as per pxFlow structure. For example user completes pxFlow(OutcomeFlow_2) page assignment , system is taking to pxFlow(OutcomeFlow_1) assignment to perform. But my user wants to see always pxFlow(Analysis) Assignment Page.
My question here is : Is it possible to change the order of the pxflow? Please let us know if there are any solutions.
Observations : Tried same scenario is 8.2 version. pxFlow is forming sequencially, means first assignment will be pxflow(firstPage) ....In my scenario first assignment is pxFlow(Analysis) . After user performs any assignment it is automatically taking to pxFlow(Analysis). I am able to change the order of pxflow however I want, but in 7.3 I am not able to do that.
Thank you,
Savitha
Hello Savitha,
There is no guarantee of the order of a page group. In fact, it shouldn't matter because you will always need to reference the page you want explicitly. I'm not sure I follow your business requirement, though I expect there is a way to meet it. Are you saying that when you resolve the assignment for pxFlow(OutcomeFlow_2) you want to see the perform harness for the assignment on pxFlow(Analysis) and instead you are seeing pxFlow(OutcomeFlow_1) ? pxFlow acts like a call stack, so I would assume you are seeing that OutcomeFlow_2 is called from OutcomeFlow_1 and that's why you end up there. Is it possible that in Pega 8.3 they are both being called directly from Analysis? I would look at the data on the pages in the two versions, my guess is there is a difference in the contents of the pages that accounts for the difference in behavior, not the order on the clipboard.
Mike
