EY Advisory & Consulting Co., Ltd.
JP
Last activity: 26 Jun 2018 4:17 EDT
Is it possible to change the column size that is already optimized?
If yes, please let me know how to do that.
Yes you can do that.
Refer the below link for the approach
https://collaborate.pega.com/discussion/alter-db-column-size-while-optimizing-properties
https://collaborate.pega.com/question/increasing-size-column-pega
Thank You
JP
Thank you for your support.
I checked "Modify Schema" but the subjected property was disabled so I was not able to change the column size.
How can I change it?
Best Regards,
I might need to check this but if you looking for quick solution and if you have access to DB, change this from backend itself and restart to apply changes.
JP
Thank you,
Bits In Glass
Hi
Here we have two options
- If your server is on cloud, then ask pega team to increase column size in database. For this you need to raise a Pega SR.
- If you have Database access then you can change the column size using alter table statement
JP
I will try it.
Bits In Glass
Hi
Please ask pega team to Clear cache and restart server after updating column
Bits In Glass
Hi
Did you raise an SR?
JP
I haven't raised an SR yet.
I will let you know it after raising an SR.
When you open the SR, please reference this post and let us know the SR Id here for tracking.
Thank you!
JP
