issues uploading the nba designer template for retail banking into Pega 8.6
@reddh Hi Ravi/All, I have issue uploading the NBA designer template for retail banking. I have tried couple of things. Like re-installing the Pega 8.6 , installing the cdh core 8.6, Setting up CDH Application, Installing the FS data model and then try to install the NBA-D Template for retail banking. Before this i have setup my context dictionary and saved it and then tried to import the NBA-D template. but every time i get the same java error: java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
I did tried to install the template in sequence like first unchecked every thing in the template and only checked channel. Here i am able to see the container rules getting created and after i get the above error. I closed the CDH and re-launched and again selected the NBA-D template and this time checked the constrains and Engagement policy but again i get the above error. For Reference I have attached the logs. Kindly help in fixing this issue.
