Issues deleting data type
I am encountering an issue with a data type in PRPC 7.1.9. When I try to add a record to my data table, a popup appears and says "pxCreateRecord API failed". Rather than try to resolve that, I figured it was easier to simply delete the data type and then create a new one. I opened the data explorer, used the menu item and selected "Remove from application" as described here:
I logged out and logged back just in case, then I tried to create a new data type using the same name and same class structure. The error message on that was "this instance already exists". So I tried creating a new data type using "Existing data type" and the data type reappeared, but it had the same problem.
How do I drop a data type and recreate it so that it doesn't have the same issues? Delete the class?
Data-Admin-DB-Table is exactly the class instance you want to include.
Also the individual instances for the class you're migrating if the intent is to copy data also.
I'm fairly prescriptive in my product rules in order to ensure that everything I'm migrating I deliberately have intended to; However, if you select an application in the product, then tick include associated data, I believe this will include all the necessary rules for the data classes defined in your application rule (All those in your Data Explorer.)
