Gmail
Last activity: 18 Apr 2018 3:55 EDT
Issue in jumping to steps of previous stage
We have an issue in jumping to the step of previous stage which is already completed. On doing change stage from stage 3 to stage 2, the steps are not executed. We do not have any start when rules on steps. It is automatically moving to stage 4. Please assist
Regards
J.P. Morgan Services India PVT Ltd
HI,
we already have this question asked in psc, you can refer the below links:
https://collaborate.pega.com/question/jump-previous-step-inside-stage
https://collaborate.pega.com/discussion/jumping-between-stages-and-steps-under-different-stages
https://collaborate.pega.com/question/moving-back-previous-step-same-stage
Gmail
These links do not have the issue that I have reported. First and third is about jumping to previous step of same stage. The second link has similar issue but resolution is not provided.
You can use pxChangeStage API
Can you please check what happens when you do the same in Stage2. Actually, I want to understand is the issue exist for all the stages or only for some stages. Also, share how you are trying to move within the stages.
Rachit
Infosys Ltd
Hi Rachana,
I am facing the same issue did u find any fix for this ? If so please share it here.
Varun
Thank you for posting your query on PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write a Post button that’s available on the top right pane of this page. Once created, please reply back here with the URL of the new post.
We have also sent you a private message opening up a communication channel in case you have any further questions.
Gmail
Hi Varun.
Run on reentry checkbox should be selected for the stages to which you want to jump back. This should work
Rachana
Sowmya Lam Rachana Jayasimha
Bits In Glass
Hi Rachana,
Please open corresponding "Case Type" Rule then Select stages tab then select corresponding stage and then goto Automatically launched processes then check run on re-entry? checkbox. Please find attachment
This will solve your problem
Sowmya Lam
