Issue with the import of a Database Table rule that maps an external DB View
I'm facing an issue when I try to import a product that contains a database table rule which maps an external database view (on a DB2 system): during the import of the package, Pega tries to create an SQL DDL in order to update that view (that actually doesn't contains any kind of change), but going throught the process, selecting the "automatic schema changes" option, the system fails (but that's not the true issue); the problem is that even if I disable the import of that view on the system (by uncheck it), Pega tries to import it anyway. It seems like the checkbox modification doesn't work (picture attached). How can I solve that without removing the DB table instance from the product?
