Issue generating DDL or upgrading application to pega 8.6.3 on DB2zOS v12
I have recently tried and upgraded PRPC 8.5.3 to 8.6.3 connecting from RHEL 7 application server to DB2zOS database dual schema v12 and to generate the DDL from Command Line it took
BUILD SUCCESSFUL
Total time: 123 minutes 47 seconds
This is with using a 4x16 VM and allocating the following custom property.
custom.jvm.args=-Xcompressedrefs -verbose:gc -Xverbosegclog:/tempDir/pegagc.log -Xgcpolicy:gencon -Xmn8192m -Xmx10240m
JDBC Driver version is 4.31
BUILD SUCCESSFUL
To upgrade the application with out upgrading the custom application the process took the following time.
BUILD SUCCESSFUL
Total time: 320 minutes 12 seconds
The reason for this is the process is reading the SYSIBM,SYSFUN and not using the indexes to do so.
PLAN
+ Thread: Plan=DISTSERV Connid=SERVER Corrid=db2jcc_appli Authid=XXXXXX
+ Dist : Type=DATABASE ACCESS, Luwid=GA027727.B95C.DB579342D4D7=92593
+ Location : :: Proprietary information hidden
+ DB2: DDD3
call
+ SQL call is active, call information is as follows :
+ Thread Status = IN-SQL-CALL SQL Request Type = DYNAMIC
+ Total SQL Reqs = 3 SQL Call Type = OPEN
+ SQL DBRM Name = SYSLH200 SQL Statement Number = 00000
+ Collection ID = NUL12510
+ select STYPE from SYSIBM.SYSCOPY where tsname in (select tsname from SYS
+ IBM.SYSTABLES where name = ?) order by timestamp desc
statements are 10 to 15 second as it is reading syscopy and other catalog tables.
SYSCOPY contain information about copies, loads etc.
The key on SYSCOPY is DBNAME. TSNAME is second column so you are getting a non matching index scan.
After explaining all that Has anyone ran across this problem before and is there a patch from Pega out there to fix this problem.
***Edited by Moderator: Pooja Gadige to add capability tag, change category from Product to Update***
