Issue with Gatling Scripts
We are trying to perform load testing of an application using Gatling tool. We have noticed that when executing a recorded scenario via Gatling, Pega is losing transaction boundaries. We see the following message in logs after the first commit in performed through the script:
2018-06-18 04:26:41,871 [http-nio-8070-exec-6] [TABTHREAD1] [ ] [ NMQ:01.01.01] ( mgmt.base.ThreadUITransaction) ERROR nmq.tal.xx.com|xx.xx.xx.xx CSPlanner2 - ERROR: posted transaction id 'be5828c5bea8678175038c305b1149ce' for frame 'pyWorkPage' DOES NOT match record 'cd264acbd3cb53b561ed5d2864a26feb'
The above problem occurs ONLY while executing scripts through Gatling. The same scenario when run manually works fine.
