The Hartford
Last activity: 21 May 2025 9:23 EDT
Issue with flow action load on process flow assignment - PEGA Infinity 24.2 Constellation
We have added two connector flow actions in a process flow with likelihood 60 and 40 respectively.
At run time I can see only the connector flow action with highest likelihood loaded by default and the other connector action is not available on the process flow assignment.
I have never seen this issue in theme cosmos, can someone assist if they have come across this behavior.
I also tried adding the other connector flow action to case wide actions on the case type, doing so lists the flow action but while selecting this flow action system throws an error "Connector Flow Action is not a valid action to use."
