Express Scripts
Last activity: 8 Sep 2016 6:57 EDT
Install Pega on Linux Tomcat
We are trying to install Pega on tomcat.
Followed the steps outlined in the tomcat install document with oracle.
On tomcat start up getting the error as in the attached catalina logs.
Please advice if I am missing anything in configuration and/or libs,database connection wise.
I tested the db connectivity from external tool and it connects fine - without any issues.
Murli.
you engine did not find the right 7.2.1 schemas, it was still looking for code set version of 61sp2. Attach your context.xml and also make sure you are not using your own prconfig/prbootstrap.properties. Use all OOTB configuration first, get it working and then you can adjust if necessary.
