Inherited Duplicate Checking issue
When creating a new class based on a parent class whose workflow contains a Check for Duplicates step and selecting to inherit the workflow from the parent, if no changes are made to the Check for Duplicates step, then the child case type uses the CheckForDuplicates flow of the parent case type. This results in duplicate checking using instances of the parent case type instead of the child case type.
In these situations, could the Flow belonging to the parent case type be automatically Saved As using the child case type?
