Accenture
Last activity: 14 Feb 2016 6:42 EST
Information required for Build automation
We completed Deployment Automation for our client using Utils script from Pega and some parametrized script (Shell script).
Now need to start Build automation.
I can see a lot options in prpcUtils.properties for export / create a deployment package.
Can some one give me some scenarios like..
Is it possible to create a deployment package using only RuleSet Name & Version in prpcUtils.properties? (Multiple RuleSet Names & Versions).
If it is not possible , What are the mandatory inputs / parameters we are supposed to mention in prpcUtils.properties file ?
Please find the below highlighted parameters from Export / build part from prpcUtils.properties file.
############################### SETTINGS FOR EXPORT TOOL ##########################
# FULL PATH TO ARCHIVE (REQUIRED) :
export.archive.full.path=
# Identify a Rule-Admin-Product instance by its pzInsKey (EXPORT RAP only)
export.archive.productkey=
# CLASSES TO INCLUDE (REQUIRED -- if not specifying a product key):
# classes.included : classes to include, separate classes by commas (no spaces)
# included.descendent : true (include descendants)
# NOT required if exporting a list of pzInsKeys
export.classes.included=
export.included.descendent=true
# CLASSES TO EXCLUDE
# classes.excluded : classes to exclude, separate classes by commas (no spaces)
# excluded.descendent : true (exclude descendants)
# For example, if including classes with descendants (Rule-) you can use this
# to filter specific classes
export.classes.excluded=
export.excluded.descendent=true
# RULESET VERSION RANGE :
# Specifies a minimum RuleSet version for Rule Resolved instances
# of Rule- (e.g. 05- or 05-01-01)
export.startVersion=
export.endVersion=
# Full path to a file which contains instances to export
# identified by pzInsKey, 1 per line.
# if exporting a list of pzInsKeys, do not provide other arguments such as export.classes.included
export.keys.file=
# RULESET NAME :
# Include instances of this RuleSet (for Rule- classes). This is case sensitive (e.g. pass Pega-Desktop, not pega-desktop)
export.ruleset.name=
# Specify application name (only one) with version for exporting ABV ruleset in this application's context.
# For example, PegaRULES!07.10
export.application.context=
# Preserve lock property on checked out instances
# Only use if moving the corresponding locked instance
export.preserve.locks=false
# MIGRATION EXPORT :
# Both of the following properties are required for a migration export
# full-path to the XML File containing classes to export
# example: export.migration.xml=C:/users/administrator/exportClasses.xml
# export all instances created or updated after, uses format: YYYY MM DD hh mm ss S a
# example: for March 15, 2012 04:42:00:0 PM, set export.migration.date="2012 03 15 04 42 00 0 PM"
