INFO logging does not work despite correct correct new log category
I want an activity to log informational data to the Pega logfile. For that I created a new log category and used the content of element JavaClassName (in View XML of the activity) in the 'Loggers' field (in my case the value is: Rule_Obj_Activity_Rule_RuleSet_Name_OpruimenLegeRulesetsOokDieZonderRulesetVersie010101_Action_20250818T102526_910_GMT).
In Admin Studio I set the Current log level to INFO (so both Default and Current log level are INFO)
In de activity I use Log-Message method en also there I set the log level parameter to INFO (also tried 'Info')
But still the log line is not poppin up in the Pega log. The only way it works when I use parameter value 'InfoForced' in stead of 'Info' . But this not what I want: it should work with value 'Info' or am I wrong?
Why is it not working?
- Yes: I double checked if I have entered the correct value in the 'Loggers' field (since JavaClassName changes all the time you check-out/check-in)
- Yes: I double checked if I used the correct filter on de logfile (I see de logline when log level is InfoForced)
