Last activity: 17 Jan 2020 5:04 EST
incorrect BIX extract output for property values with new lines
Hi Team,
we are facing an issue with our bix extract output. Whenever a property in the extract rule is having values which includes new line, it is producing an incorrect output. A new record is created after the new line char and the entire record is splitted into multiple records in the extract. Please let me know if someone has faced similar issues and what is the solution/workaround.
Actual property value :
"Sample Example Text
07/02/19
$3,462.17
Control #: XXXXXXXXXXX"
In the extract we should be having a single record. But we are seeing the extract as below.
BIX Extract :
Hi Team,
07/02/19
$3,462.17
BIX Extract :
DT|"T-57295448"|"I-42390341"|"C-57029720"|"20190708T233421.457 GMT"|"20190708T233421.516 GMT"|""|"T-57295448"|"Pending-Outcome"|"true"|"P"|"Y"|"N"|"EC"|""|""|""|"N/A"|""|"20190708"|"20190702T070000.000 GMT"|"Our Customer Service Dept"|"20190702T070000.000 GMT"|"Our Customer Service Dept"|""|""|"OC"|"20190708"|""|""|""|""|""|"3462.17"|"XXXXX"|""|"Success"|"XXXXX"|"N"|"N"|""|""|""|""|""|"D"|""|""|""|""|"Y"|""|"1"|"OCDDT01"|""|""|"false"|"A"|"N"|"N"|""|"67"|"EMPTY"|"EMPTY"|"EMPTY"|""|""|"170"|"FAILURE"|"~"|""|""|"EMPTY"|""|"9999999999"|""|""|"20190708"|"EMPTY"|"0900"|"T-57295448:9999999999:DDT:EC:0900:N:N:N:false:No:N:A:XXXXXXXXX:N::N:N:N/A"|"Sample Example Text
DT|
DT|
DT|"|""|"20190708"|""|"20190702"|"3462.17"|"070820191634214250"|"XXXXXXXXXXXXX"|"20190702"|"9999999999"|"2019-07-08 16.34.21.426"|"0900"|""|""|""|""|"XXXXXXXXXXX"|"C"|"1"|"RJF"|"XXXXXXXXXXX"|"VBK40150"|""|"0"|"VBK40532"|"00"|"XXXXXXX"|""|"No"|""|""|""|"N"|""|""|""|""|"NA"|""|""|"VBK10334=VBK30343;VBK10334=VBK30343;VBK11478=VBK30001;VBK10336=VBK30335;VBK10822=Yes;VBK10823=20190702;VBK10825=3462.17;VBK10826=3462.17;VBK11259=VBK30440;VBK10928=VBK30000;VBK10946=VBK30020;VBK10946=VBK30412;"|"true"|"Yes"|""|""|"Other"|""|""|""|"N"|"Other"|""|""|""|""|""|""|"N"|""|""|""|""|""|""|""|""|""|""|"No"|"false"|"false"|"N"|"N"|""|""|"N"|"N"|""|"N"|""|""|"N"|""|"N"|"N"|"OC"|"N"|""|"N"|""|"DDT"|"N"|"N"|"N"|""|"N"|"N"|"N"|""|"N"|"N"|""|"N"|"N"|"N"|"N"|"N"|"Y"|""|""|"N"|"N"|"N"|"N"|""|"N"|"N"|"N"|"N"|"N"|"N"|""|""|"N"|"N"|""|""|"Phone/Computer"|"Other"|"Other"|"No"|""|""|""|""|"3462.17"|""|""|""|""|"N"|"N"|"N"|"Y"|""|"N"|""|""|""|"N"|"N"|"N"|"N"|"N"|"N"|"N"|"N"|"N"|"N"|"N"|"N"|""|"N"|"N"|"N"|"N"|"N"|""|""|""|""|""|""|"20190702"|""|"OCDDT01"
