Mphasis Unleash the Next
Last activity: 25 Sep 2017 7:19 EDT
IE getting stuck/Not Responding while running the solution.
Hi Team,
After running a solution in PEGA the automation is able to login into a website and after that it is getting stuck i.e. the IE is not responding.(i checked the website by opening it manually there is no issue with the website).
It worked fine in Open Span and after migrating to PEGA i made many trials to run it. After many trials it ran succesfully only once and again when i tried to run the solution i came across the same issue.
Is it due to the browser? if so how can i change the browser for the solution.(i have gone through a post where changing the browser is given by selecting universal web application but i need to change the browser for already existing solution which i did with web application)
Please guide me to solve the issue.
