NTT Data
NTT Data
Posted: Dec 27, 2018
Last activity: Dec 29, 2018
Last activity: 29 Dec 2018 12:21 EST
Identifying ECS-Enterprise Class Structure Work/Data/Int Elements
How do classify ECS elements as work , Data , Int elements after ECS creation
- Any Data Page holds Service End Point URLs – can be considered as Data Page – Is In Data correct
- Service Rule – Service Soap , Service Rest – Is considered as Int elements correct?
- Section , Report Definition can be – either in Work or Data correct?
- Service Activity – can be considered as Int element correct?
- Cache Report is coming from System - so it comes under Int element since from system other work , data elements won’t fit
- When rule can be any where it could be under work , data even Int correct?
- Flow is always under work correct?
- Property holds reference data page - is it mean Data Element?
- Property holds the data – is it means data element? Since mostly property can be defined in work or data or int element.
