I cannnot use Pega Field Service default customer data (PegaFSM-Data-Accounts)
Hello.
I tried to install Pega Field Service, but I faced error and I couldn’t use default customer data (PegaFSM-Data-Accounts). So I need your help to solve this problem.
I use Pega Platform 8.2. I installed Pega Field Service 8.2.1 following “pega-field-service-82-installation-guide_1”. I tried to install the sample data (SampleDB/FieldServiceSample.jar), but I got following error message (more detail, please see attachment file “SC_SampleImportError.png”).
“Save Failed Database-Config-KeyPropertynotExposed PegaFSM-Data-Accounts BusinessUnitID.”
I have built Pega Platform on Linux VM and internal DB on SQL Server on Windows VM on Azure. I have confirmed that there are no problems with the access right and capacity of the DB. Actually, other sample data was registered at the time of sample data import.
I couldn’t resolve this problem. So I would be grateful if you would send me some information.
Thank you.
