How to use Java Code inside Declare Expression ?
I am new to Pega , please help me regarding how to achieve this functionality
I have a Date Input Field where User can select his Date Of Birth .
When ever there is a change inside Date Of Birth Field , the Age Property must be calculated Automatically
i want to Write a Declare Expression for this on the Age Property
I have this sample piece of java code , which gives me the age based on Date Of Birth provided
Could you please tell me how can i use this piece of code inside the Declare Expression .
(If this is not the right approach to do , please let me know also )
public class TradeCustomerAgeCalculator {
public static void main(String[] args) throws Exception {
String input = "1981-01-01";
SimpleDateFormat sdf = new SimpleDateFormat("yyyy-MM-dd");
Calendar dob = Calendar.getInstance();
dob.setTime(sdf.parse(input));
System.out.println("Age is:" + getAge(dob));
// Returns age given the date of birth
public static int getAge(Calendar dob) throws Exception {
Calendar today = Calendar.getInstance();
int curYear = today.get(Calendar.YEAR);
int dobYear = dob.get(Calendar.YEAR);
int age = curYear - dobYear;
int curMonth = today.get(Calendar.MONTH);
int dobMonth = dob.get(Calendar.MONTH);
if (dobMonth > curMonth) {
age--;
} else if (dobMonth == curMonth) {
int curDay = today.get(Calendar.DAY_OF_MONTH);
int dobDay = dob.get(Calendar.DAY_OF_MONTH);
if (dobDay > curDay) {
age--;
return age;
No jars. Create a function rule in Pega. Your java code is just using JDK out of the box packages.Create a pega function. The imports should be correctly included for all packages in the function itself. Then write the java code inside the function. You may find out the option to create function under Technical category. Once the function is added then you may use it inside the Declare Expression.
