How to use built-in JS logger?
Hello all,
I am doing quite a lot of front-end development in JavaScript on Pega 7.4 and I discovered that there is a JS interface for getting log messages from native Pega controls.
There is a pega.widget.Logger that might be visible on UI but I find no way to enable it. Moreover it is not either loaded or available in global context.
Modifying IsAPegaDeveloper when rule gives access to brief description of logBase, logBaseMonitor, and others but there is no examples of usage.
Is there any way to enable this Logger? Maybe, we can reuse it for our custom controls, cannot we?
For logs to show up on the console, should not the typical console.log( ) be enough ? Do you want logs from JS files to show up in the pega logs ?
