How to update classes etc. after changed WSDL?
I need to re-run the Connector Accelerator wizard, but the Pega help seems to be inaccurate:
Updating classes and properties after WSDL or XSD changes
If you have produced a SOAP connector using the Metadata and Connector Accelerator, and later obtain updated WSDL or XSD files, you do not need to re-run the accelerator. You can generate the needed class and property changes from the XML Stream rule form and XML Parse rule form:
- Using Save As, copy the current XML Stream rule or XML Parse rule into an unlocked RuleSet version.
- Identify the XSD or WSDL file on the XML tab.
- Click the Update button on the Mapping tab.
- Save the rule form.
I don't find this Update-button anywhere on a Parse-XML, XML stream or Connect-SOAP rule - how does this work? If I try to re-run the wizard it would create every existing class with a ending "2" in addition - which is not updating. I already checked and the RuleSets are unlocked.
