Optum Global Solutions
Last activity: 12 Jun 2018 17:02 EDT
How to trigger OpenSpan using a web application built on Pega?
I am currently working on OpenSpan. I need to trigger Pega Robotics Studio on the basis of button click on my web application which is built on Pega. In other words, if I click the button in the web application, the OpenSpan starts and runs the automation and returns the desired results. It is not same as button click event as in OpenSpan. The button click will trigger the Pega Robotics Studio to start, run the automation and return the desired results. Is this possible in OpenSpan and how?
Thanks.
Please look through the material found at this link. It is not possible to trigger the Runtime to start as you request - it needs to be running before you trigger it. An activity can trigger an automation either in pre-processing or post-processing.
