How to set dynamic value into Connect-File >> [File Name] ?
I have question about If it is possible to set dynamic value as below into Connect- File [File Name] property?
I tried , but it not worked. It seems like the [File Name] property could be only get
values from clipboard page. Here is the invoke activity for Connect File.
So, what I did is as below is set file name value into a clipboard property (.pyFileName) in the previous step before calling connect-file method in activity.
And set the file name property in connect file rule as below.
Is this a common way that how we can set the file name dynamically?
