How to Save Repeating Grid from Clipboard into Data Explorer
Hi, I'm new to PEGA. I have a problem of using repeating-grid-layout to list all the added items from clipboard, saving all of them into the data in PEGA. I'm using activity to loop and save, also already tracer that activity which only have 2 sequence; activity begins and activity ends. It seems that in the first step of activity there's a mistake. So here's my step:
Please CMIIW, first: I'm using loop For Each Embedded Page, the embedded page is my class path Case (SMMF-EventMan-Work-EventAdmin).
Secondly, the step page when looping is a PageList which contains the clipboard data.
Third, I want it to loop for all the details data in clipboard (ex: if there's .pxResults(5) then it will loop 5 times according to results)
After testing the case, there's neither errors information display nor the data is being saved in Class-Data. I wonder if my approach is wrong, or if there's another way to save Page List? (FYI: I'm using 7.2.1)
Thanks.
***Updated by Moderator: Marissa to remove secure information from image***
It is already resolved. Thank you.
I just need to loop repeat "For Each Element Value List" in the step which using property-set method. (I mention earlier that I'm using Activity)
Then inside property-set method, I used pyWorkPage.MyPageList(<CURRENT>).MyPropertyPageList for the properties value input. After that I add child step and set the method obj-save.
This is the syntax that I missed out : "(<CURRENT>)"
