How is pxThread.pxReqURI determined?
Please could somebody elaborate on how is the pxReqURI string determined for a pxThread?
Hi Saurabh,
PxReqURI is built based on these three attributes.
1. AppContext - prweb
2. AccessGroup HashCode - SOME_AUTO_GENERATED_HASH_CODE (Randomly generated based on user's access group)
3. ThreadName - PRPC thread name (STANDARD, TABTHREAD, PORTAL Threads etc..)
So typically pxThread.pxReqURI would be combination of
/AppContext/AccessGroup_Hashcode*/!ThreadName
Eg:-
/prweb/k1FvsMuBzj07DoioYpInDRgUumuQTbMz*/!OpenPortal
/prweb/k1FvsMuBzj07DoioYpInDRgUumuQTbMz*/!STANDARD
-Harish
Thank you Harish that was helpful.
Would you be able to tell which PEGA OOB utility determines/calculates the ReqURI?
Pega Support Center has detected you are using a browser which may prevent you from experiencing the site as intended. To improve your experience, please update your browser.
