Coforge
Last activity: 30 Nov 2015 14:46 EST
How to provide tcp endpoint url in connect-soap
Can you please clarify 'tcp endpoint'? Do you mean SOAP endpoint URL or not? if yes, see the help document: https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
Coforge
I mean endpoint URL only. Actually endpoint url of webservice which i am trying to invoke is tcp://host:port. When i am passing it as endpoint url and testing connectivity, its throwing exception "java.net.MalformedURLException: unknown protocol: tcp"
I believe, you can't use a tcp://host:port/ URL, try using only host:port
You need to use protocol http not tcp.
Coforge
If i am using http, getting connection refused.
How to create tcp socket connection and then pass request
I meant...use http://host:port as URL
PEG
You need to give hostname and the Listen Port number in the end point URL of Connect-SOAP.
http://hostname:Listen Port Number/ ---
Coforge
Could you please explain it more detail
