Last activity: 12 Sep 2017 19:50 EDT
How to pass POST request in body using REST connector..?
Hello Friends
I have a REST service which accepts json payload in http body.
I designed a REST connector and chose POST as method to fire request. It created the integration class with property .request (Page property which contains .body_POST which is another page property pointing to another class)
E.g. Sample json payload is like {"key1":"value1", "key2":"value2", "key3":"value3"}
E.g. Org-Int-RESTAPI {.request}
Org-Int-RESTAPI_REQUEST (.body_POST)
Org-Int-RESTAPI_Body_POST
Note : request and body_post don't pattern-inherit from RESTAPI. It uses "_" rather than "-".
a) I tried creating text properties in Org-Int-RESTAPI_Body_POST and then call Connect-REST (MapFrom : JSON, Map from Key: .request) in Activity using this request, but I get
the HTTP response code of 415 indicated a client error.
Hello Friends
b) Then I tried MapFrom : CONSTANT, Map from Key: {"key1":"value1", "key2":"value2", "key3":"value3"}. But it didn't work either.
Can someone assist with this.?
Is the request header Content-Type required and set? i.e. "application/json"
