Accenture
Last activity: 15 Dec 2015 0:42 EST
How to pass parameter/multiple parameter to the preactivity of pege.desktop.showHarness?
Here multiple parameter means Param1,Param2 etc.
could you please try ...
- @param $String$preActivityParams - Parameters of preActivity. Format: Comma sperated key:value string.
note: the function 'pega.desktop.showharness' is defined in RULE-FILE-TEXT WEBWB PEGA_DESKTOP_API!JS
CVS Health
Hello Rasaiya,
Your question is not clear. Are you talking about the param info while calling the Show-Harness?? Pls elaborate more on what exactly you are looking for.
Ravi Kumar.
Accenture
pega.desktop.showharness comes in run script
Accenture
here you can see 2 parameters preactivity and preacrivityparam, my question is related to preactvityparams , how to pass multiple value here
Accenture
Thanks for the reply friend will try and share the result
Accenture
for reference purpose is there any pega rule this syntax is used?
Accenture
It worked , still looking for some inbuilt pega rule, where they have used this parameter. Let me know if you find any.
Thanks âº
