How to pass param key(assignment key) dynamically with Open assignment action in Mashup with Encryption On
Hi ,
We are creating a mashup channel with using Open Assignment as action and passing param key as assignment key of one case ID with encryption on.
We have to open the assignment of each and every case in the worklist or workbasket , and same code is used in front end application . While opening the assignment, it always open the case of the assignment key which we are passing in the channel , eventhough the correct value is displayed in div tag param from the front end applicaiton.
What value should we pass in the param key while creating channel so it opens the correct assignment always.
Note: This is having issue only with ENCRYPTION ON.
