How to move altered columns in Pega Data Schema to Higher environments
I have increased column size (pymemo) in the History-HRServices-Work which is mapped to Pega Data base schema using Schema tools from landing page in pega in Dev.
Issue:
When we move Data table instance pzInsKey for pr_History_HRServices_Work to higher environment changes are not reflecting any approach is appreciated.
Below are the ways which i tired but did not work
1) After increasing the column length,opened the instance of Data-Admin-DB-Table specific to the History class and resave it and moved the Data base instance key to higher environment..
Vikram
