Accenture
Last activity: 27 Jul 2016 10:16 EDT
How many work objects can be loaded for mobile offline?
We are currently building a mobile app with an offline capability. We created a specifc portal and access group. I have selected the case types to enabled offline and i also enabled offline in the access group.
When i try to login into the custom build app the work objects are not loaded and i get a error message: "Failed to load stream!".
When i go back to my access group and disable offline support and login again into the app the workobjects are shown. For me it looks like that there are some restrictions on the amount of work objects i can load for offline support.
Can someone help me with this problem?
Thanks!
Once you login to your app, were you able to see the sync icon that appears in the top right corner of the screen ?
There are no such limits set for work objects. In any case can you conditionalize your report definition to return only 20 work object and check once again.
