how to integrate pega with kafka
Hi all,
we have a task to integrate pega with kafka, I have followed below document to configure the kafka and populated the trust store and key store. if I didn't check the 'Use authentication' box, the connectivity will be expiry due to time out.
Show More
Hi all,
we have a task to integrate pega with kafka, I have followed below document to configure the kafka and populated the trust store and key store. if I didn't check the 'Use authentication' box, the connectivity will be expiry due to time out. But if check the 'Use authentication' box, below error will pop up, may I know if any one have ideas on this,,,, thanks.
btw, may I know how to configure the jaas conf file, as I have jaas file and krb5 file on hand as well.. thanks.
Connection failed
Error connecting to Kafka. Failed to construct kafka consumer. java.io.IOException: Configuration Error:
Line 1: expected [{], found [logging]. Configuration Error:
Show Less
