How to identify which node is picked in file listener when Startup option is "Host based startup"
I am using file listener for BIX file extraction. I would like to set up this functionality only for one specific node on our server. I am planning to use Host based startup option where node count is set to 1. Is it possible to verify which node is picked up for processing. Is it the same node all the time or will it keeps changing. how do i identify it.
Please provide your suggestions/inputs.
Appreciate your help. Thanks in advance
