Optum
How to generate excel or CSV file and upload data from pagelist directly
How to generate excel or CSV file and upload data from page list directly.
Likes (1)
KANCHIPATI ARJUN VARA KANCHIPATI -
You can use OOTB activity @baseclass.pxConvertResultsToCSV to convert page list to CSV.
Updated: 14 Mar 2020 1:13 EDT
Optum
Thanks Praneeth for the reply. I am unable to find the activity ( we are using version 7.1.6.) Do I need to add any prerequisites to see the activity in my application?
Updated: 14 Jun 2021 7:38 EDT
pxConvertResultsToCSV activity is a final activity, if you want to see it in your search, in the operator preferences, check "Enable diagnostic features" and search again. Or Call this activity from other activity and click on Crosshair icon.
Optum
Yes I tried that already. I am getting below error.
'Rule-Obj-Activity instance not found: @baseclass.pxConvertResultsToCSV. Details: Invalid value for Activity name passed to ActivityAssembler'
Optum
any update plz
IQZ Systems
Hi
Can you try using Call Rule-Obj-Report-Definition.pxConvertResultsToCSV in your activity.
I am assuming that you have created an activity and using this in one of the steps. If so "call @baseclass.pxConvertResultsToCSV" should work. And the error you mentioned above will be because it is unable to find the rule in the inheritance path but you are mentioning @baseclass explicitly while calling the activity and it should not be the case. Try using Call Rule-Obj-Report-Definition.pxConvertResultsToCSV which is the same activity in Rule-Obj-Report-Definition.
Updated: 22 Mar 2020 22:39 EDT
Optum
Yes I tried that l already, but in my application I am unable to find the activity. PFA.
Can you please let me know if I need to add any prerequisites to get that activity.
Could you please check if "Pega-RulesEngine" ruleset is there in the Pega Platform(Pega-RULES) application stack.
Optum
pxConvertResultsToCSV rule is implemented in Pega 7.1.7 and later, but my application is in 7.1.6 that why it is not showing for me.
any other approach to upload data from page list to CSV or excel directly.
Please find the below article which might be helpful.
https://collaborate.pega.com/question/how-can-i-export-page-list-contents-excel
