How to fetch XML data with 'select single node'?
I want to fetch the highlighted field in the image.
On selectSingleNode's xpath, how do I define a name space?
Provide namespace values in xpath string only.
I already tried, and it says that the name space is not defined.
Try with below code.
var xmlDoc = new XmlDocument();
xmlDoc.Load(@"filename");
var namespaceName = "ns";
var namespacePrefix = string.Empty;
XmlNamespaceManager nameSpaceManager = null;
XmlNodeList nodeList = xmlDoc.SelectNodes(string.Format("/{0}fileresponse/{0}data/{0}folder/{0}pages", namespacePrefix), nameSpaceManager);
if (nodeList != null)
foreach (XmlNode childNode in nodeList)
string first = childNode.ChildNodes[0].ChildNodes[1].ChildNodes[1].InnerText;
below is sample xml:
<fileresponse>
<data>
<filename>abc</filename>
<filetype>1</filetype>
<folder>
<name>pega</name>
<documentid>123</documentid>
<pages>
<NS1:Page xmlns:NS1="http://b.ws">
<NS1:Deleted>yes</NS1:Deleted>
<NS1:Id>
<NS1:Id>3131231232</NS1:Id>
<NS1:RefId>12refid</NS1:RefId>
</NS1:Id>
<NS1:PageNumber>1</NS1:PageNumber>
</NS1:Page>
</pages>
</folder>
</data>
</fileresponse>
Hi Jayachandra,
Thanks for the work-around I'll check and confirm.
I was just wondering why can't I use 'select single node' method since xpath can handle namespaces as well. Could it be a limitation of the method?
I have another question.
I gave my XPath as '/FileResponse/Data/folder[3]/Subfolder[1]/Pages/page[1]/RefId' on select single node method.
It's not returning the value.
