How does system identify multiple nodes as the same cluster?
Hazelcast is a purely distributed and decentralized cluster. Hence there is no master node concept and each member joins a certain cluster somehow. My question is, how does each member identify each other as the same cluster? I know if you specify members ip address in the prconfig.xml file it works but I want to know how system handles this without prconfig.xml, using an empty table (pr_sys_statusnodes). I find "pxClusterID" in the table but is this the one that groups nodes? If so, how is this determined?
If I ask differently, how can force "Split-Brain Syndrome" to occur (https://community.pega.com/knowledgebase/articles/system-administration/split-brain-syndrome-and-cluster-fracturing-faqs)? I tried starting Tomcat at multiple nodes at the same time but it doesn't seem to happen. Why?
