How does one tell OpenSpan that an object passed to another automation Uses Keys.
If I pass an object that Uses Keys to another Automation wherein I want to address that object using keys, how do I tell OpenSpan that the passed object uses keys? I suspect there might be a way to modify the .os file, but I really don't want to do that. If I do have to do that, exactly what do I need to do?
This little bit below is derived from an example on the OpenSpan support site: https://support.openspan.com/link/portal/9147/9147/Article/195/How-do-I-use-keys-to-navigate-between-multiple-instances-of-an-object. Calc is set to UseKeys. It gets set up in Automation1 and the Object (the This) is passed to Automation2.
See attached code if you are confused.
