CitiCorp
Last activity: 4 Apr 2019 9:10 EDT
How do we Customize the pyConfirmationNote message?
Could any one of you help me is understanding how the "pyConfirmationNote" field value works and how/where to customize them as per our requirements?
Example:
1 ) pyConfirmationNote - Thank you for your input :
2) pyConfirmationNote - pyStepRoutedConfirmation :
Thanks in advance.
Parasanth
Swedbank AB
SE
Hi ,
This values will load from field values. Pega created various field values as below. You can update in application layer if required.
Hi ,
Typ
Namn
Applies to
PegaFS-Work
@baseclass
@baseclass
PegaReq-Work-ProcessRequirement
Work-
PegaCRM-Work-
PegaFS-Data-Account-Card
Deva
Su Zhu
CitiCorp
Hi Deva,
Thanks for the guidence, but as the values for pyCaption are loaded by selecting in the Cell Properties as shown below.
Where do you use/Configure the "pyConfirmationNote" field value after Creating it?
Prasanth
Bhuwan Chitransh
Swedbank AB
SE
You can refer pyConfirmMessage section.
Tata Consultancy Services
Hi Prasanth,
You can override the existing confirmation note in DT by setting value to pyConfirmationNote Property.
CitiCorp
Thanks Gayatri,
I am able to over ride the existing pyConfirmationNote with my variant.
pyConfirmationNote TestNote rule:
Overriding in DT:
Output :
Thanks Gayatri,
Overriding in DT:
Output :
But can anyone suggest how does the Field value for "pyConfirmationNote" Filed name gets updated in backend, Because for each scenario the Field value is changing?
Prasanth
Hello Prasanth,
To check where this value is getting picked, you can open a tracer and then keep a watch on this variable. Using this approach, you shall be able to find where the property is getting changed.
Rachit
TCS
Could you please tell me why we will get as No data available instead of Thanku for your Input.I have not customized any thing.
