How to display columns conditionally based on rows property in table layout
Hi all,
I have a requirement to display note message and links next to columns of a table layout. I tried adding new column and put paragraph rule in it. But it is not displaying as expected.
2 lines of note message should display next to 2nd column and next 2 lines should display to 3rd column.
Another requirement is I have to create one text field below 2nd column and another text field should appear below 3 rd column.
Also when I add paragraph rule in a new column and every column width is taking as paragraph content. I don't want to happen that.
Below is the picture to be created.
Kindly help me out.
@DeepakM60
Note text has to come from the table context . Not as a paragraph rule.
Lets say the table is sourced from Datapage . D_TableData.pxResults(X).pyNote should contain the text .
So you can directly refer them in the table .
