How to create a new application in Pega 7.2.2 personal edition?
I just downloaded Pega 7.2.2 personal edition but while creating a new application from PegaRules Icon-> New application I was taken to a template based screen and asked to select a template on which I would like to create the application. While selecting the custom template and going to advanced configuration I could see 2 options- Framework and Implementation. Is there no way that I can select the application structure as Framework and implementation at the same time, like in previous Pega versions? Does this mean I would need to create a framework first and then create another application based on the framework?
In the academy lessons i can see this - Select the type of application you want to create. Choose Enterprise application to create an application with a reusable class structure, case types, data types, and organizational rules. Choose Express application if you do not require a reusable class structure, or you are inviting another user to explore the Pega Express environment.
But I cannot find any option which allows me to select between Enterprise application and express application. Is that because its a personal edition?
Please suggest what's the best way to create an application in 7.2.2 as Implementation and framework.
